- Feb 28, 2001
- Dayton Oregon
- 2.3 (4 Cylinder)
- Total Lift
- 6
- Tire Size
- 35"
How does it work? A couple years ago the dome light quit working with the passenger door, a couple weeks ago the dome light quit working with the drivers door. The light works with the headlight switch. I figured it would be the door jamb switch, replaced the drivers side switch and still doesn't work. I think I remember something about the circuit going through the headlight switch? Where do the 3 wires on the switch go? I didn't look too close at the 3 pins, I did look close enough that they aren't corroded or broken off... I'm assuming orientation doesn't matter as there was no keying on the switch connector...
