doing a 94 ford ranger 2.3 to 5.0 swap need help!
a 5.0.
5.0 trans
time and money.
what are the goals? 2wd 4wd?
daily driver? play toy???
are you stuck on a 5.0? consider a ls type powertrain? a later hemi?
Read the tech articles section on engines--all the basic information is there. Then, as you get into it you will have to make "search this forum" (the V8 forum) your favorite place to click. This is like doing a research paper without writing the paper--instead you turn your research into a cool truck.
I am looking to get spoon fed, if never done it before and I'm gonna need some expert advice! It's gonna be a drift truck, so what motor would yall recommend? Looking to go cheep if possible, took the box off today and had some fun with it
You've got a lot of reading to do. Do a search on 94 V8 swaps at the top of the thread, then read. The swap itself is fairly easy...
Vaughn Gittin uses a foxbody mustang with a crate pushrod 5.0 and a T5 with 2.73 gears for his "playtoy". I'd run that setup except with 3.08 gears since the truck is lighter in the back...
SVT
