muddin76
- Feb 16, 2008
- Age
- 49
I recently had a problem. When I go to 4hi or lo my front driveshaft locks and all that works, BUT, when I try to go my front tires wont pull. I locked the hubs, did like I was told on here, jacked up one side with hub locked (warn manual) the tire and axle turn, even if in 4 wheel. I thought maybe a spun axle. Well I was told today that when the fluid in a ford front end wears down it wont function. I was told that there is a clutch pack that works for the limited slip. When the oil breaks down this will not let the clutches work right and I would not have a working or in this case locking front end. Yes the hubs lock and axles turn with tires. But will not turn the front drive shaft. front shaft does lock in gear when in 4wheel. Does this sound right, would the gear oil when broken down after many many miles not allow the gears or limited slip function right? Its like I have a slip on both sides when under pressure. I did check the fluid today, full. BUT its very worn down, not much oilness to it, plus traces of water, I am changing it this weekend. Just curious if anyone feels that this may fix my trouble, a simple oil change. Also , which side is the power tire, driver or passenger?
