Do you need the bigger wires for a screaming demon coil?
cp2295
Washougal, wa
If you ain't first you're last
On summit racing it says you need their 10mm wire set, which costs more than the coil pack. I keep reading on the forums and everyone says they replaced their pack with one of these and the trucks running better and everything but they don't address whether or not they got the bigger wires too. Just wondering if anyone's running the pack without the bigger wires and got the plugs at .065?
Just curious too does anyone know what stock coils put out? Can't seem to find that anywhere, the screamin demons claim they put out 45k volts
I have the Accel coil and the wires are ok, if they stay dry and if the don't touch each other or anything else. A decent set of 8mm wires should do the trick.
I did have problems with my Motorcraft plugs burning up @ 0.065", switched to NGK Iridium plugs and haven't had an issue yet.
Sent from my HTCONE using Tapatalk
