94 4.0 5-spd 4wd ranger
my lift is finally done after a full weekend and half a weekday, with my spicer adjustable bushings in it, it doesnt look like im far off at all with my camber. i have a pull right so i know im going to have to adjust the caster on it, i am wondering where everyone has take their readings from when they measure their caster and camber. i have seen the tech article on alignment and noticed that the member who posted it tore down to the knuckle to measure his caster and camber but i know that if i support the beams any way other than with the wheel itself taking the weight it will throw off the ride height and make the measurements invalid. So again just wondering if anyone has some other reference points to put a protractor/angle gauge on for when the wheel is still on. im thinking back of the rotor but havent gotten to take a crack at it yet. the ranger is sitting out in the drive way on some angle iron and socket extension rollers to relieve any compression/tension awaiting an alignment in the morning
