differential/rear axle noise
krnrpkt
I'm sure you all have heard this story before!
With 126,000 miles on my 96 Ranger 4.0L 4x4, extended cab, I'm now getting some rear end noise...sounds like a low growl/whrrr sound starting to be heard around 20 mph and more prominent at 30+ and more pronounced when steering to the left. I do have a slow leak from the rear axle seal on the passenger side and was probably down 1/2 pint to at most 1 pint of gear oil in the differential before I caught fact of the leak.
So, I'm suspecting some damage somewhere in the rear of the truck, maybe a rear axle bearing on the passenger side or a scored axle shaft.
I drained the differential and saw no visible indication of damage inside the housing - no metal particles or chipped gears visible.
I'm thinking of pulling the axles and having not done so before, I had a quesion about the c-clips. After removing the pinion shaft and pusing in the axles to expose the c-clips, are the clips going to be positioned in a way such that they can be removed with needle nose pliers? Is there enough of a lip on the clip to grab onto with pliers or do they need to be pried up a bit with a screwdriver? Do the c-clips rotate around the groove in the axle shaft? Do you need to try to rotate the c-clips so that the opening of the clip is facing down so that they can be removed by lifting up. I just like to know what to expect before starting the job.
Any insight or tips would be greatly appreciated.
Thanks...Jim
I would suspect a FRONT wheel bearing if the noise changes when you steer.
To answer your c-clip question, the clips should be loose when you push the axle in. Use a magnetic picker-upper to get them out.
Just hope the crosspin bolt isn't broken when you go to pull it out, big PITA.
