The_Dealer
ok heres the deal. i fixed the brake light issue, on 85's the light green wire in the 2 wire duraspark plug goes to the brake lights. so when i wired it into the red/lt blue wire the brake lights were staying lit up with the ignition on. So i got that fixed, and redid my wiring one more time. everything is correct with my wiring. so now i have a couple questions. im on my third duraspark module. they keep burning up. i also went to summit racing and got their brand canister style coil with ballast resister(oil filled).
so my question is, i dont have alot of options right now with mounting for the module and coil. i have one bolt in the coil holder where the cruise controle thingy was, and i have the old ground wire on the mounting bolt. is this enough to ground the coil? also the way its mounted its kind of at a sideways angle(tilted about 45*), is this bad for the coil?
ok, so why would i keep burning up the modules? i didnt have a ballast resister on the stock coil, and i only have one mounting mounting bolt in the module to ground it out. i also have a ground wire from the mounting bolt to the ground strap going to the block.
next the only thing that looks important is a small(about 14g) wire that is in the loom going from the ground cable on the battery to down by the bottom of the motor on the passenger side. theres a single wire plug that went to about 5 different black wires. what should i have this to? also i have a wire going from the coil + to the starter relay I, ive read that that keeps the module from overheating.
can anyone see what i am doing wrong to where im burning up these modules? i can get it to start once and after that it dies and the module is burnt. this is the last one they will let me swap in, after this i have to start buying em. also i didnt have the harness that plugs into the distributor and duraspark box, so i cut the ends off and wired them up with 14g wire. the guy at advance said thats whats killing them. is he right? so far ive spent about half of my avatar pic on trying to get this thing running, please help!
