Broosedamoose
DaMoose is lose!
- Mar 10, 2012
- 4.0 V6
- Automatic
- Tire Size
- 31 x 10.5
- My credo
- Coming in second just makes you the first loser!
Well, here we go again! I guess it's what I should expect for an old truck with 250K miles. It's been starting up fine since finding the 12V coil fuse was corroded and replacing it. Now all of a sudden it has to crank for a bit before starting. A couple times it didn't start at all until I turned the key Off and tried again! I checked the fuse and both the fuse and the socket are fine. When I turn the key to start, it cranks for anywhere from 2 to 5 seconds before it fires up. Sometimes it fires right up though. I can hear the fuel pump run when I turn the key On so it's not that. I tried spraying Starting Fluid in the intake before trying to start it but it still cranked for a couple seconds before starting. I've tried turning the key to the On position for a couple seconds before starting but it makes no difference. I'm afraid I'm going to be out somewhere and then it won't start at all! I checked for codes but there are none. It's hard to check anything because it does start after a few seconds. I'm scratching my head now!
