Oh2Ranger
Hey guys, hopefully a quick question. I'm trying to get all my information straight for tomorrows run at the truck.
Here is a little background:
I have a 1994 Ranger, had 3.27's stock. Was not working out well for my setup. I grabbed a LS 3.73 rear and swapped it into the back, now I'm working on the front.
I got the pumpkin out, (took 1500 hours, blood and swearing) and ran into a few snags along the the removal. The front pumpkin I removed from the junk yard came apart pretty nice, it was out of a 93 explorer. Mine fought me the entire time. The spindle / axle housing? This piece here:
was seized and had to be beat off with a chisel, screwdrivers, sledge.. etc. It was not easy. Anyway, when It did come off, it came off in pieces (internally, seals etc.). Are these housings compatible with rangers? How about the axle shafts? My passenger shaft (splined shaft) would absolutely not separate. It took an unbelieveable amount of WD40 muscle and leverage to get the thing to come out. The splines look like they weren't seated in the groove and somebody pounded it in or something. Are the Explorer and Ranger axles shafts the same length? What is compatable, and what is model specific on these? Hubs? Shafts.. etc. If I need to go back to the yard and get the pieces I've already pulled, I need to do it sooner that later.
Thanks!
Thanks!
