HsOffRoad
Does anyone know why Moog Lists two separate part numbers for their D35 TTB ball joints, depending on the build date of the vehicle?
Moog D35 TTB Ball Joint P/Ns:
Build Date Prior to 1/11/1993 - Upper – K8546
Build Date Prior to 1/11/1993 - Lower – K8563
Build Date 1/11/1993 & Later - Upper - K8676
Build Date 1/11/1993 & Later - Lower – K8673
Moog even has a TSB type of form about this (form DYK10-102) where they break all of this down for you.
Link to PDF of Moog form:
http://www.moogproblemsolver.com/_pdf/_did_you_knows/DYK10-102E.pdf
This doesn't make sense to me, because the Dana/Spicer build sheet (along with other manufacturers like Raybestos, etc.), list the ball joints as being identical - and offer only one P/N for all TTB D35s, from 1990-1997.
The Moog website doesn't list dimensions for their products, and from the pictures that they display for the two P/Ns, they appear identical.
If anyone can shed some light on what is going on here, and what (if anything) changed in the D35 TTB knuckles/beams on 1/11/1993, I would certainly appreciate it.
Thanks,
-Hans
Thanks,
-Hans
