Crankcase ventilation filter
auto117584
The big black filter that connects air intake hose to crankcase, located behind the power steering and A/C bracket, is called what? I've got it soaking in paint thinner overnight. Is it enough to shake it vigorously with thinner in it, or is there a preferred method for cleaning it? Or do they get replaced? Couldn't find anything about maintenance for it in the Haynes book. 95 B2300
PCV valve? Picture? Not completely sure what you are talking about.
This thing sits forward of the oil filter and slightly higher than it. In the case of too-high crankcase pressure, the blow-by gases go through it and up to the intake air filter. Otherwise, under normal conditions, it allows intake air into the crankcase, via a hose that plugs into the top of it. The bottom tube slides into a hole, and there's a single bolt to hold it there.
I just took a picture of the spare one I have, with the computer monitor built-in webcam, but can't figure out how to attach it.
I got know idea what you are talking about either......if you had a pic that would help, however when you do figure out what it is please come back and post the answer......
it's the crankcase ventilation filter.
heree's a picture of it
album.php
I googled it all i can fine is that it is a MOD that some people think is good and others are not sure if it works
Link is not present and the pic didnt show up.
right click on the picture icon, open in new tab, click twice on the picture and it will open the picture to full size
Should I stand on my head and rub my tummy too?
Lol. I can't do all that from my phone.
i stood on my head and rubbed my tummy while right clicking on and trying to open it in a new tab........... and it still would not open
i went and looked at my truck and there is a black thing about 4" by 3". it iis fastened to the block and my pcv valve goes into it. I never noticed it before. it looks like it would be a total pina to remove...... I cant answer your question about cleaning it...........but less us know what you figure out
