2.3L ('83-'97) Crank sensor
BruceTarver
Ive got a 1994 ranger 2.3 internal crank sensor, is the motor thats being removed. Ive got a real good 1995 2.3 external crank sensor that i own. The party that im having swap them out tells me it will not work because of the crank sensor diffferences is there a simple solution for this??
Welcome to TRS :)
No, there is no simple, or otherwise solution
1989-1994 2.3l is different from 1995-1997 2.3l
Its not placement of the crank sensor, 1994 uses DC volt(hall effect) crank sensor, 1995 uses AC volt(VR), there is no electrical conversion for these two signals
Thank you for the info, u saved me a lot of effort into resolving this. Thanks again
