Welcome to TRS
First thing
CEL(check engine light) should come on with key on, this means computer has powered up
When you turn the key to START and engine starts to turn the CEL should go OFF, this mean Crank sensor is OK and computer is getting a Good Timing signal
If above happens.............
Next test is to pull off the large air tube on the intake
Spray gasoline or Quick Start(ether) into the intake, you can leave the tube off, don't let fan hit it
Try to start engine
If it starts, runs and dies, you have a fuel delivery issue
If it doesn't start then you have no spark(or no compression)
Called the 50/50 test, been used since the 1890's and first gasoline engines
The 4.0l SOHC does have several timing gears that can slip, which causes no or low compression
If 50/50 test has a no start no fire result then test 1 cylinder on each side for compression
170psi is expected
Under 120psi would be no start
If CEL doesn't come on then computer is not powering up so no start
Check fuse 11, 30amp, in Engine bay fuse box
