Craigslist Picture Size LARGE?
R***A**N**G**E***R
Ok so by DEFAULT via the craigslist software you can up load 4 small pictures to be seen with your ad, however I have seen HUGE pictures that are not posted using the default method so my question is who here knows the trick to posting normal to large size pictures on craigslist along with your ad.:dunno:
Use photobucket.com...
Just a hunch, but if you have Photoshop, "save as" the jpegs as quality 4 out of 12. I think that the maximum size upload limit for CL is dictated by filesize regardless of pixel dimensions. I think this is ONE way that you can do it. This means that you could have a very good quality picture that is actually small, and vice versa.
I'm sure there are other ways.
try putting the image location between those to codes or tags or whatever they are. link them from somewhere like photobucket and it should work. the web browser should recognize it as html code and display it as such. at least that's how i understand it works
to copy the image location, right click on the image and select 'copy image location', paste the location in between the img /img things from above
the img tags are for forums, its not gonna work on craigslist. i think what you need to do is host them somewhere and use html code to embed an image. i've never done it, but it should work. i used to know a little html back when myspace was cool :dunno:
oh, seems like i've done it before, i have no idea, i'm lucky i know where the power button is on my computer
Photobucket has an HTML code... its this one:
<a href="http://photobucket.com" target="_blank"><img src="http://i91.photobucket.com/albums/k308/4020fan/st.png" border="0" alt="Photobucket"></a>
Yea that's the first thing I tried.
Ok well I just did a test, that was easy and I should of known better,so yea copy and paste the html link into your ad and you get full size pics.Duh:icon_twisted:
