Cyberbeer
I'm starting to get a little frustrated with this truck. Two weeks ago I replaced a leaky heater core. Five days later the truck started to get hot but only after about 35-40 minutes of driving (speeds of 45-55mph), I never let it get upto the H, but it did get into the O. So i started hunting for leaks...found one on the overflow bottle, and the thermo housing was missing its gasket. Replaced the overflow and put a gasket on the housing yesterday.
Drove the truck to college today and it everything was fine until I hit that damn 40 min mark and it started to get hot again. So I pulled over checked the coolant level which turned out to be fine. So let it cool down from O to M and drove it the rest of the way. It hit the O again right before parking, so I decided to try an experiment and just sat there and let it idle for 10 minutes. By the end of that time the temp had stabilized right between the R and M.
So I am stuck, drive it longer then 30 mins it starts getting hot, stop and simply idle it begins to go down. The thermostat is only 3 weeks old, fresh coolant, new heater core, new hoses, new rad cap, new overflow bottle, and new thermo housing gasket. Any ideas?
