5337
Greetings everyone, just joined the forum.
I have a 2000 Ranger XLT 4WD with 4.0 and A/T and 112,300 miles and have been smelling coolant for a couple months.
I have checked radiator, water pump, hoses, thermostat housing and everything looks good.
So today, while I had some extra time I found a leak coming from the front cover on the engine. You can actually see the dampness coming from between the block and the cover on the right side.
What is involved with replacing this gasket? Haynes manual says the engine will have to be removed to replace it. Is there another way or will I have to take it to the shop to have it done.
Any ideas what a Ford dealer would charge to repair it?
Thanks,
Tim
Thanks,
Tim
