khardrunner14
- Dec 3, 2007
2002
- Automatic
This may be kind of an odd question, but bear with me as I'm new to the duratech.
The bottom hose running from the block to the radiator on my truck is constantly cold, even when the thermostat is open, while the top hose is hot. Normally, I would expect the opposite as the coolant should flow from the top of the radiator, through the block and back to the bottom of the radiator. Is the flow reversed in this motor or do I need a new thermostat?
