scarface
- Sep 15, 2007
- Automatic
found an adapter to use an 700r4 to a 4.0
don't see why it wouldn't work on a 2.9
here's what the page said
not sure if links are allowed
#56A4LD. We now have an adapter to install a 2.8L type 700R4 transmission on a Ford Ranger, Aerostar or Explorer with a 4L engine. The small bell housing 2.8L 700R4 transmission can be built to V8 specs. This kit will fit 2WD and 4WD with the weaker A4LD transmission. The bellhousing kit comes with a new bellhousing adapter plate, torque converter adapter ring, crank bushing, necessary hardware and instructions. The transfer case kit comes with a new output shaft for the transmission and the transfer case adapter. Cost, Bellhousing kit $399.00, Transfer case kit $460.00
