Comp cams 49-410-8
Superbad119
Winder, Ga
I need help figuring what push rod size you guys are running for 49-410-8 cam shaft. I'm using the stock rocker arms.
I'm not big on 4.0 cams but how much lift different from stock cam to this cam
Sent from my SAMSUNG-SM-G870A using Tapatalk
Not too much different. It adds a bit lower end torque and suppose to help gas millage. I'm not 100% certain on its specs. But I know the base circle is smaller.
The stock cam was
.384/.402
Performance cam
.465/.5
By the way it's it
Intake needs to add .081 to the pushrods
Exhaust needs to add .098 to the pushrods.
Now this is a not true the only way to fine out for sure buy a push rod checker. They make two.
One is a plastic pice that sit on the rock.
Second is an adjustable push rod to get the length.
If the lifers have been primed no need to add if the are dry I user add .020 for lifter.
Thanks Angie for the link. Good read about it. Guess I'll tear into it again and get them ordered
