Common Problem Fix, Noisy Power Steering Pump
Blown
There are many fixes in a can or bottle that don't work. Probably many more that don't work than do. I can attest that you can count on Lucas Oil Power Steering Stop Leak. I have used it in three of Ford's noisy power steering pumps and had success in quieting all three. Quieting yes, but I can't attest to it stopping leaks yet, though we just put a bottle in my sons Dakota to see. The seal on the passenger side of the rack is leaking slightly.
I used a turkey baster to remove most of the old fluid from the pump reservoir and added a full bottle of Lucas each time. Problem solved! :icon_thumby:
From Lucas:
"Universal Power Steering Stop Leak (10011) by Lucas Oil®, 32 oz. Lucas Steering Stop Leak is 100% guaranteed to stop seal leaks in power steering units or your money back. Totally corrects rack and pinion problems. It is also totally effective in reducing slack, squeals and hard spots in worn rack and pinions. Your results will be immediate and long lasting."
So far my solution for the noisy power steering pump has worked great. And t doesn't cost anything!
Granted, my Ps isn't too noisy yet either.
My solution? Turn up the radio [emoji14]
Sent from my SM-N910V using Tapatalk
On my rig it is hard to hear the power steering pump over the whine of the Blower.
Disclaimer: I do not own stock in nor work for Lucas Oil, really, it just works.
