cold air intakes
If you really want one, make it yourself. But really, the stock flows more than the engine can use. Don't always believe the K&N performance hype. It's way over rated. :)
The stock set up is already designed to draw cold air. The K&Ns draw air from under the hood where it gets heated by the engine.
The only advantage of the K&N filters is that they are re-usable.
