Hardwareman
I just did a 2.5 swap into my 95 Ranger that had a 2.3 in it. Before you ask why, the reason was because my old 2.3 had 370,000 miles on it and the blowby and loss of power was horrible. I managed to fix my breaking timing belt tensioner problem as well.
Anyways before I did the swap I had a code of P0340 on the old 2.3. I figured old worn out motor, but after I installed the 2.5 I got the same code along with the random misfire and sputtering problem. What gives! A whole different engine and a whole different cam sensor too! I basically only used the 2.5 block so the problem has to lie somewhere within the older components right?
I did some online searching and found that the voltage regulator on the alternator can send wierd current through the wiring harness and cause my symptoms along with this code. And my wife and I were talking about when I got this alternator. It was right around April when I needed my smog check and I remember being worried because that's when the misfire started on the 2.3 (not as bad back then though) and I was praying my truck would pass.
Does this make sense to anyone? Thanks
Allen
Allen
