Loud Ranger
So lately my clutch wont disengage all the way. If i start it in gear it rolls forward unless i hold the brakes too. It wont go into 1st or reverse when stopped so i have to put it in 1st or 2nd while slowing down then hold the clutch and brake to the floor at lights. It feels like theres not much clutch pedal at all till about halfway down then its still pretty soft. After about 10 mins of driving its gets easy to shift into gear when its warmed up and the pedal will build pressure.
If i had air in the system it would always be soft right even after warming up?
Im thinking its a bad master since it wont build pressure and the clutch pedal was making a weird chirping squeaking sound before this started happening. That and the clutch and slave were replaced 2 years ago.
Hoping i can get this straightened out before winter since my only other transportation is a motorcycle which isnt gonna cut it in a mn winter.
