I installed a 5.0 and 5 spd into 1996 ranger, flywheel, pressure plate and disc are new, trans from 1989? f150, slave is what came on trans. Pedal effort seems normal, very little play at top, travel all the way to floor seems normal. I see this a common swap, does ranger master always work with f150 slave? Problem is can't shift with engine running, if started in gear truck wants to drive away. Where's the problem?
