2 bronco 11s
I guess this was my lucky week! Clutch line blew off twice . Read and seen dozens that have had this problem . Here is Perfection Clutch reply . Black end go to black regardless of a clip or push in style. Has fingers inside . Same as the goldish color . Which we all knew. Here’s the problem with the clip style . It must be able to make a complete 360 turn once installed. It will move even though it is attached to a non moving fitting ?? and relieve pressure off the clip and allow it to come out. He said notch the tranny out so it clears. Factory fords at least the 2 I have , there centered in the hole . The aftermarket sits almost all the way to the front upper side. My suggestion is to by the one without the clip. The M5 is a very tight fit going in . Live and learn .
