whitebroncoii87
I'm changing out the clutch, while the flywheel is exposed, is it a good idea to sand the flywheel with sandpaper? Or just be real careful with it and wipe it with a rag?
Also while installing the pilot bearing, should I put some grease on the outside surface of the bearing where it makes contact with the crankshaft/flywheel hole, or leave that dry the way it is? Thank you!
