Cluster lights are out.
Vigy86
Hey, my fuel guage and temp guage lights are both out. I don't know if its a fuse or a simple bulb problem. The weird thing is the tach and speedo still light up. Anyways, let me know if you have any thoughts and/or ideas, and how to go about replacing needed parts. I do NOT want to pay someone to do a simple job like this. Thank you for any help!
If you remove the instrument cluster to replace the bulb, you might as well change the illumination lamps over to LEDs, more than likely saving you from having the same problem again down the road. Kind of strange to have a burned out bulb on a 2007 model already, but you never know. LED's are cheap and there's info in the tech library about them. Also, I like this article:
http://howtomatthew.blogspot.com/2009/05/replacing-dashboard-lights.html
There are about 5+/- bulbs behind that panel. I had one go out on the 03. You just have to take the radio surround, the panel under the steering column, the metal panel under that, and finally the cluster out. I may have missed some steps but you get that there are a lot of overlapping panels. The face just unbolted on my cluster and you could get to the bulbs
