CHeck engine light on p1151
953.0M5
Check engine light on p1151
Hey everyone! Newb here. I had a question about my 95 ranger 3.0. I'm new to the Ranger world and could use help. I recently had the clutch in my ranger replaced and after I received it back the check engine light has come on with a code of 1151. It says lack of O2 sensor switch bank 2 sensor 1. Then it goes on to explain that it could be caused by low or high fuel pressure, a dirty or damaged MAF sensor, a vacuum leak, or bad injector or pressure regulator. I'm not sure if anyone has had this problem before, but if they have any advice would be greatly appreciated. I plan on replacing the O2s on it weather they are bad or not because I think they are still the stock ones. The truck has about 143,000 on it at this point. I was worried that the pressure regulator could be bad but I'm not sure where the fuel pressure is supposed to be at. Mine is at 34-36 at idle and jumps to maybe 40 with a quick hit of the throttle. I have noticed a drop in mileage since I bought the truck about 9 months ago. I used to get about 300 miles on 3/4 tank of gas, and the last I check I was getting about 250 miles on 3/4 of a tank. I have recently done a tune-up on it including an accel coil pack. It also has a K&N replacement filter and Flowmaster 50 series muffler. Again, any help with this would be greatly appreciated!
take it back to the shop that did the work and kindly explain the situation. theres a chance something was left unplugged or even broken during the transmission removal.
I called them the day I got it back about the many things that were wrong with it. They told me that they did not see any problems with the vehicle when they test drove it so it couldn't be anything that they had done. :annoyed: That is the exact reason that I hate taking my vehicles to a shop. But, I live 2 hours from my parents house in an apartment and my buddy and I ran out of time trying to get the trans out. I did however look the truck over a little better today and found that the vacuum line going into the throttle body from the evap canister was cracked. Kinda hoping that is the problem but am doubting it. I put electrical tape around it for now but will replace it this weekend. Stupid work always getting in the way! lol
