nealdarty
- Feb 4, 2009
- Automatic
Just changed timing belt on 90 2.3L. Every time I try to crank the truck it idles real high for a second then dies. I have the haines manual and have read over this section several times and can't seem to get the timing set correct. I lined the camshaft triangle up with the mark on the engine case, lined up the aux. shaft triangle at 12 o'clock, and turn the crankshaft to tdc. Put the belt on and truck idles high and dies. I have tried to set the crankshaft to 10 deg. btdc and 20 deg btdc and the samething. Does anyone know where I maybe going wrong?
