CEL Light not Working; Replaced Bulb
Ranger4x4.0
Poplar Bluff, Mo
God is great, beer is good, and rangers are awesome!
It worked fine before, and then it went out after taking it to the shop. I just got done replacing all the bulbs back there and it still does not work. I would really like it to work. Tia.
Sent from my SAMSUNG S7 using Crapatalk
first thing that popped into my mind when i read this was.... what did you take it to a shop to get done? and maybe shop slit a wire by accident?
1998 should have a 7.5amp fuse, #11 in cab fuse box
That powers the CEL bulb slot when key is on, also powers other things.
The computer GROUNDS the bulb to turn on the CEL, pin #2 on the computer connector, Pink/light green stripe wire
Check the fuse first, most likely issue
Then on back of the instrument panel there are 3 multi-wire connectors, 214, 215, 216
on 215 look for the Pink/light green stripe wire, pin 9, that's the GROUND wire from computer, it should be a GROUND when you first turn on the key
Right next to it, pin 8, is the wire from the 7.5amp fuse, Red/yellow stripe wire, it should have 12volts when key is on
If both of those test OK then problem will be in the dash circuit board
Wow, I totally expected some really sarcastic answers to this one, and not completely legitimate diagnostics of the CEL and how it works.
I checked the fuse, it's not blown. I guess I'm not gonna worry about it if it's a cut wire somewhere. Thanks for the reply!
