choltzapple
I have a 97 B2300 and I'm changing the timing belt. I've changed a couple TB before but I've never had this problem. No matter what I do, it's half a tooth off somewhere. I have the Camshaft and Oil pump pulleys lined up (triangle to triangle, and diamond to diamond) and the crankshaft lined up (key at 12 o'clock and line at the TC mark). I have fought with it for two days and installed the belt countless times and I get the same result every time. I took a picture showing how it sits right now. The belt is installed and the cam and oil pump are lined up perfectly, but the crankshaft has moved half a tooth. This is as close as I can get it, is it good enough? If not, what can I do?
http://imgur.com/Kx7gV4F
Edit: I should note that I counted the teeth on the belt already and double checked the part number. 131 teeth and P/N is right.
