1986ranger
OK, I am troubleshooting a truck and ran into something I don't understand. I understand when you pull the SPOUT it is locked at base timing. So with the timing light connected to the number one plug wire, the timing pointer on the balancer should be at the 10* mark. In an attempt to see if the others were getting spark from the distributor, I checked the timing on the other cylinders just to make sure there were at least making the timing light flash. When I did this, they all were making the timing light go. This, I thought, was good. Now here is where I get confused. On all 6 cylinders the timing light illuminated the balancer in the exact same spot, on the 10* mark. I check this on another known good running truck and got the same results. How is this possible? Keep in mind this was was all done with a VERY cheap timing light.
