Camshaft bearing installed wrong?
backerm
Tucson, AZ
I took my 4.0L push rod engine to the machine shop and had them install the new camshaft bearings as I always do. So now its time to slide the camshaft inside and the last oil hole is blocked off! Is this really the case, or does the last bearing not have a oil hole?
Every journal/bearing gets an oil feed...
  • Like
Reactions: gaz
Yea, after looking at a different angle and a mirror I can see the hole is there. I guess my eyes aren't what they used to be. Thanks for your help.
  • Like
Reactions: gaz
You get points for checking instead of just jamming it together and finding out later that it was wrong.
