Boomers13
Had to take a break on the truck for a few weeks because my girlfriend had her baby. Finally got a chance to finish the timing belt and sensor swap last weekend. I started it up and it still ran the same. I had cleared the codes before i started it. After I started it three or four times and got it to where It would idle on its own, the code for the sensor popped up again. I unplugged The sensor while the engine was running and there was no change whatsoever. I suspect a broken wire somewhere is the cause. Before I rewire the sensor I need To test the plug to make sure that's the problem. How do I do that? If that is the problem then what is the ecu pin location for the sensor? Thanks in advance for any help. It will be greatly appreciated.
