ford4wd08
Was reading through the tech library, and came across the recommendations for T Case fluid.
Does it really make a difference which fluid is used? Especially in the early 1350 cases like in my B2?
I was thinking of using Valvoline's T-Case fluid in mine as it is readily available and the T Case doesn't hold much to begin with, even if it is a little pricey.
