BroncoII 7.5" WMS to WMS measure?
JoseBronco
Hi,
I would like to know WMS to WMS measures for the BroncoII 7.5" axle. On the tech library is a sheet that says 56.5" for a 7.5 axle but I don´t know if it is a Ranger or a BroncoII axle, or if it is the same measure for both.
Thanks
The info is in the 7.5/8.8 section but kind of buried. Looks like the passenger side of the BII is 1 5/8" wider than the early Ranger.
Dave
The early 1983-1992 Ranger axles are 1" shorter than the 1993-up pieces. (Both sides) meaning that the an entire Ranger axle assembly from 1993-up is 2-inches wider than 1983-1992.
The right side Bronco II axle shaft is 1-5/8" wider than the 1983-1992 Ranger shaft. All of this additional width is in the passenger side. The drivers side shaft is the same length in either axle assembly.
On ALL Ranger/bronco II's the drivers side axle shaft is longer than the passenger side.
Yes, the BII axle is right about 58" WMS-WMS.
