Nalanthi
- Jul 10, 2013
- Automatic
Good evening, y'all and Merry Christmas.
As usual, I pop around here and there to post to get ideas/exhaust what I already know to help me problem solve. Writing about it helps.
I've been enjoying the 4.0 swap for a good two and a half months now, but ran into quite the issue I can't put my finger on. After work last Thursday, my starter ground the flywheel. I put it in neutral and coasted a foot or two before starting and being off on my way. When I got home, I crawled under and found that the bottom bolt on the starter was loose - to which I tightened. The next few starts were rough - sounded quite metallic, but without grinding. Sunday rolls around and the starter did not catch the flywheel at all - sounded like it was catching... something... but not a major grinding sound.
Here's what I know:
I swapped between two starters with the same results. The teeth on both the starter and flywheel are not ground out or missing. The bendix ejects and the starters both test fine - so the starter(s) and the flywheel are not an issue.
The only thing I didn't do yet was check the tranny bolts to make sure the bellhousing was tight - aside from that, there are no obvious signs that one would normally expect...
Any ideas, gents?
Thanks as always.
On a side note, I got 33s rolling on this thing with inch and a half spacers and a bit of fender cutting - didn't want to lift right away due to my fear of rolling, but it doesn't rub one bit - not even on the sway bar. Should post a pic sometime.
Here's what I know:
Any ideas, gents?
Thanks as always.
