BishNasty
- Apr 15, 2012
Hi guys,
I have a stock 5spd 87 bronco II. I'm looking to lift the truck so I want stronger axles, I found a 92 parts explorer for a couple hundred bucks. its got about 200k on it with a rebuilt 4.0 auto trans.
Now my questions are will I be able to use both front and rear axles from the explorer on the bronco? I'm prettty sure its a ttb dana35 in the front I'm not sure what's in the rear. Also will I have any issues with lifting the truck after I do the axle swap? Lastly I was wondering if I wanted to possibly do the 4.0 swap at some point, would it be better to use the one out of the explorer and find a manual trans or just wait till I want to do the swap and go get one from the junk yard with a manual trans?
Anything helps.
Thanks
Anything helps.
Thanks
