macx
- Oct 21, 2011
Recently bought a 93 2.3 4 cyl 5 speed cheap as a backup.
Saw it had been neglected - no servicing done for quite some time. But with 75k miles figured the main components were probly still OK. (Gonna do ALL fluids incl steering and brakes & trans / diff) Oh, have to pull the trans cuz the rear main seal leaks pretty good. Somehow or other, there was no leak under it when I crawled under and checked it out. Hmmmm -
When I tried it out, it started and ran smoothly and responded to the throttle with no problems, also ran Ok on the 25 mile trip home.
Put in new regular Autolite plugs, old ones (splitfires) looked OK actually, no bad deposits at least - wires etc seemed OK. Found a bad vacuum leak on the driver side in a hose attached to a good sized metal nipple coming out of the bottom of the intake, fixed that with new hose. Also changed fuel filter.
Installed a new radiator instead of trying to get the crud cleaned out of the old one, also a new T-stat, t-stat housing (old one corroded pretty bad) and lower hose. Before, it would barely get above the lowest line on temp, when I removed the T-stat it was stuck open with crud. Drained the engine, incl the block, put in radiator flush and water and went to drive it.
Immediately noted it bucked and surged pretty bad when I gave it throttle when I started out. Engine was cold, but it hadn't done that before. Idles fine, went up on fast idle and settled down to regular idle like it should. Steady speed at normal street speed is fine, but what would cause the bucking and surging when I step on it? It got a better when it warmed up, but still had to go easy on the throttle. And even with the new 192 T-stat
it didn't get even up TO the lower mark on the temp gauge in nearly 10 miles of town driving, lites, etc.
I'll check that vac line again, make sure it didn't come off.
Where's the engine temp sensor? With a new stat and cleaner fluid in a
new radiator and the block flushed, it should come up to temp fairly quickly shouldn't it?
I've worked on EEC-IV systems quite a bit, just on a 5.0.
My oem manuals came today, I'll dig into them, too.
But am really concerned about the surging - that shouldn't be happening -
also the failure to come up to temp.
Thanks for any tips / insights / experience and what to check!
