wylde8
- Oct 17, 2010
Just replaced the clutch assembly and slave cylinder on my 97 Ranger 4.0. Really the only thing left to do at this point is to bench bleed the clutch hydraulic system so I can reinstall it. I thought I had done my homework beforehand and looked into how to best do this. Everything says to remove the reservoir, clutch master cylinder, and lines, hang them up with the master cylinder pointed upwards, and bleed the system. However, when I add the brake fluid to the reservoir, the fluid just drips out of the slave cylinder connector. If I push on the pushrod of the clutch master cylinder, the fluid shoots out the bottom and empties almost immediately. What am I missing? Everything I read about the procedure said no fluid should drip out of the slave cylinder connection and bubbles should slowly release into the reservoir.
