BII lift and d35 install question?
elpoffroad
Ok well im a newb to bronco II's. I got mine for 250 bucks not running. Had to redo some wiring and unclog the fuel injectors but i got it on the road now.
My question is in my 87 i got a cheap rough country 4" lift and i was planning on doing the d35 swap since i wanted to run 33'. I got the d35 and the lift but now my question is with the lift do i need to shorten still my drive shaft?
Also i read that it needs a extended bump stop do to the plate style brackets?
do i put a bigger bump stop on the passenger side only? Were can i get a bump stop like that?
It might be very simple answers but i looked around and didnt find what i was looking for? Thanks for the help
Yes, the DS should still need shortened, can't help with the bumpstops.
With the drop plate for the passenger side beam, you need to put a longer pump stop on the drivers side of the truck. This will stop he diff from hitting the bracket for the passenger side beam.
ah so its the driver side bump stop that has to be extended :) thanks guys going to be doing the swap this weekend :icon_cheers:
