I use Belkin brand. Mine are all 750VA model (750 watt/hours).
Purchase about 1.5 times the wattage you expect to have connected to it. ONLY put the computer on each one. If you do that, you will have plenty of time to save and shut down. You should never continue to run on battery backup for your computer.
Anything non-critical should be on a surge protector, but not on battery backup. I have my computer on battery backup with delayed shutdown, my server set for auto shutdown on battery backup, and each of my 5 other comps on their own battery backup with auto shutdown. Only the main computer monitor is on battery backup, the others are on surge and turn off immediately. NONE of the sound systems, network components, or the printer are on battery backup though they are on surge protectors. They lose power immediately, just like most of the monitors.
If I lose power, 5 out of 6 hard (non-mobile) systems immediately begin saving work in progress, and shutdown on their own. My main system will run until out of delay (20 mins, battery tested for 1/2 hour run time) then begin forced save and auto shutdown. If I am working on something, I save and shutdown immediately, If I am not working on something, or am not at the computer, it will execute save and auto shutdown after 20 mins.
