Auto to manual hubs
Ryannn
Carson City, NV
I purchased these parts from summit racing, the manual hubs and the front conversion kit from auto to manual... Should I be good to go when converting the hubs?
Mile Marker 95-27997
Warn 37780
Looks good. As long as it fits the same year jeeps as the hubs.
Why not just buy warn conversion?
Take my advice, dont buy mile marker hubs Buy the warns. They are junk,IMO. Just dd mine and they broke before i even put them in 4x4. You can get the hubs and conversion kit cheaper on here on the trs parts
Mile Marker 95-27997 <--- That's the conversion kit part # from Milemarker. (spindle nut kit)
He has the Warn 37780 hubs listed that he's buying, which is the Jeep hub kit.
For what it's worth, Don't buy that spindle nut kit from Summit for $45. Get on broncograveyard.com and buy them. They're only $20
http://broncograveyard.com/bronco/i-82001A-d35-hub-conversion-kit.html
The mile marker is the nut conversion kit from auto to manual and I did buy the warn jeep hubs. That's all I should need right?
Make sure you really tighten down that lock-nut. I had to go way past the torque spec (not the inner one setting bearing load), because it worked off and chewed out the ribs inside the hub. It still functions properly and I'll have faith in it, but won't let that thing go loose again.
