brettallen59
- May 22, 2011
- Automatic
I m SO desperate! I will send someone $50 if you can tell me what fixes my 1998 Ranger 3.0 with a P0171 & P0174 Codes. I have replaced
O2 bank 2 Sensor 2
MAF
Fuel Filter
Air filter
Plugs
Intake Manifold Gasket
Large Vacuum Lines
Checked for vacuum leaks
PVC valve
Now it is real hard to start in the morning. It fires, but then dies right away. After about 7 tries, I can finally get it to stay running, but it backfires a little and I have to pump it to get it to run. It is a real bitch to get it running.
PLEASE, can someone help me! Should I do a smoke test? Replace fuel pump? What about Idle air control motor or Throttle position sensor?
I have been trying stuff for two months and doing what everyone has been telling me to do but I have run out of options. PLEASE HELP ME. Thanks!
Brett.......
O2 bank 2 Sensor 2
MAF
Fuel Filter
Air filter
Plugs
Large Vacuum Lines
PVC valve
Brett.......
