LittleHorse
My 2.9 continues it's decline day by day so I'm getting itchy to tackle this 5.0 swap thing again. Vehicle is 90 Bronco II 4x4
My plan is to use a EEC IV 5.0 HO from a Mustang (don't have the patience to try an OBD II engine from the Explorer).
Overdrive is a must, and I'd like to have an electronic transmission like the AODE or 4R70W because of all the internal upgrades they made to strengthen them over the years. According to this: http://en.wikipedia.org/wiki/Ford_AOD_transmission The AODE isn't listed for any 4x4 vehicles, instead all the 4x4s are listed as having a 4R70W.
When I go to Advance Adapters to adapt my 1354 t-case to the transmission, the listing for the part ends with this:
Nice how it just cuts off at the end before telling me the important stuff, eh? It makes no distinction between AODE and 4R70W, and makes it sound like the adapter is for the hydraulic AOD only due to the output shaft. I don't want to use a full size t-case because of the frame interference issues.
So what this boils down to is two questions:
1) To use my BW 1354 am I stuck with spending a ton of money upgrading a hydraulic AOD due to lack of available adapters for later transmissions?
2) Are the AODE and 4R70W electrically similar enough that a Mustang computer will control both an AODE or a 4R70W?
Options
The AODE (4R70W) 4 speed automatic transmission was used starting in 1991 & later. The adapter housing will fit the AODE, however, the output shaft is different in reference to the oiling. Our kits for the l
