marriedmanw
You may recall my previous post about my Grand AM 2.4cyl OHC engine making a rattle noise. The first mechanic opened the hood and listened and thought it was a spun bearing and advised to replace engine. I decided to drive to another mechanic yesterday but while in route the rattle sound stopped and engine died. The engine would crank over but not fire up. I towed to shop and mechanic looked it over and thinks the timing chain broke or jumped timing, and the valves have been damaged. He did a compression check and found 0 compression on all 4 cylinders. While cracking the engine I noticed that the cam is turning since it turns the power steering pump, so my question is: How does the cam turn if the timing chain is broken, and what would cause 0 compression on each cylinder? Do the pistons move while the engine cranks even with no timing chain?
2nd mechanic was really helpful and spent a hour looking it over doing the compression test, and charged me nothing. He said it will take a new head, valves, timing chain, etc... to fix and he advised he'd do the work but the cost would exceed the value of the car. I've towed the car home and sitting in my driveway till I figure what to do next.
I wonder if the bucket seats will fit the Ranger...
Thanks for any input.
