macdude67
Sorry to beat a dead horse but this P0401 is being a pain. Bought this 1995 2wd 3.0 automatic a yr ago and was doing some basic tune up stuff. Noticed the check engine light did not light during key cycle, it had a burned out CEL bulb. Replaced bulb to fix no light situation. Used a scan tool and had several codes but none really effected drivability. One code for canister purge, corrected that with another known good canister purge solenoid. 2 other codes, one for bank one O2 sensor heating element and other for post cat O2 sensor heating element. Fixed those with new sensors. Cleared codes and only one to keep setting is P0401. Before P0401 would set within seconds of starting. so I replaced DPFE sensor and one small hose going from EGR pipe to sensor. Later replaced EGR valve and scrubbed intake EGR port to make sure it was clear and also replace EGR vacuum source solenoid. Now after 5 to 6 miles the P0401 code comes back, I can clear code during the drive cycle and code will not come back until 5 or 6 miles into next drive cycle? Gets pretty tiring playing wack a mole with these CEL codes. About to take the bulb back out.
