Mike92STX
- Jan 14, 2012
- Zion,Illinois
- 4.0 V6
- Tire Size
- 245-75-16
I was trying to bleed my clutch to see if I could get the pedal to engage a little higher. I have one of the pumps, so I connected it to the bleeder valve and opened the valve. I tried pumping it and nothing, so I tried turning it some more still nothing. After checking the master to make sure it was not empty, I thought maybe the bleeder was plugged, so I removed it, and nothing came out even with the master still open. I put the bleeder back and snugged it down. Tried pushing the peddle nothing, goes to the floor so I crawl under and there's brake fluid on the exhaust so it's still coming out with the bleeder valve in and reasonable tight. I have a new slave but don't want to take the transmission to replace it in a day, probably can't do by myself in a day anyway.
This is a 04 Ranger FX4 4.0 FWD. I know that is a little redundant but in case someone doesn't know what the FX4 is.
