cstarbard
- Aug 10, 2017
- Age
- 31
- Oakham, MA
- My credo
- It do like it be
Hey all-
I've had multiple 2.3 Rangers with varying degrees of spark knock (pinging) and I thought I'd share my experiences chasing this issue out in case anyone else can benefit from it. As I understand it is a common and somewhat elusive problem with these engines. Two of three 2.3 trucks I've had developed it.
My current truck, 1996 2.3 4x4 with 150k miles does not burn any oil to speak of and otherwise seems pretty healthy, but alas, has begun spark knocking. It has gotten worse over the last 6 months, and is worst under load (trying to make it up steep hills for example).
So far I have done the following basic maintenance:
-plugs (platinum as I recall)
-replaced both 02 sensors (both were bad when I bought it)
-wires
-adjusted throttle cable at pedal so that slack is reduced (was only opening 75-80% before)
-new coil packs
-new WIX air filter
-cleaned MAF
-cleaned the IACV multiple times
-switched to synthetic blend oil, then full synthetic (Mobil 1 advanced protection or something like that)
-fuel filter
Despite all these things, spark knock still developed. Today I tried seafoaming the truck in three different ways (in gas tank before filling up from 1/4 tank, in crankcase, and through intake) and I have to say I am very impressed at what seafoam can do. I drove the truck several hundred miles today and while the spark knock is still there, it is dramatically reduced. For most of my driving today, it was knock free. Now the spark knock occurs seldom, even under load. Even when it does spark knock, it seems quieter than before. I have never used seafoam before and would highly recommend it to anyone dealing with this issue. I plan on running seafoam through the next few tank fill ups and see if that helps further. I may run seafoam through the crankcase before the next oil change in 5k miles as well as through the intake again, since I had such good results.
I plan on pulling a few plugs and taking a look at them as well, possibly changing again. Plugs were done 15k miles or so ago.
I will continue to update this thread with my results as I change/try things. I am hoping to completely eliminate the spark knock.
-wires
-new coil packs
-new WIX air filter
-cleaned MAF
-fuel filter
