Beef52751
I'm doing the 130 amp alt. swap on my 86 and had a couple questions. I got the new alternator of a 3.8 Taurus.
1. One of my factory wiring plugs will plug right into the new alt., it seems to be correct as well, yellow is always hot green is ignition. I just wanted to verify that I cut the white wire and run it to the single terminal on the new alternator and leave the truck side unattached?
2.it appears in the tech article that the new upper alternator bracket has 2 holes in it which I am guessing some one drilled the second hole, I was just wondering if someone had a measurement as to where this hole needs to be?
3. I assume nothing is used out of the second plug for the factory alternator since now I am charging straight to the battery?
Thanks for any advice you could offer
